Hello everyone,
Newbie here, I am MyersKimb, working with DropDMG. I want to create the mac disk images for one of my project which is related to the Smart contract technology example.The only problem I have with DropDMG is the lack of ability to change a configuration file’s settings and overwrite the presented one. Presently, I have renamed the existing configuration by adding a 1 to it’s name and then saved the new settings under the old name. This is litle bit wearisome. To add to the frustration, Automator will crash if you have a configuration file chosen in an action but delete/rename it. This is a weird bug as Automator will crash even if the workflow is not running.
I will be greatful if you point me in the right direction.
Thank you.
