I have SpamSieve 2.9.29, High Sierra on a MacBook Air, Outlook 2016 and a very large Inbox.
I have gone through the documented install and elected to set it up with the InboxSpamSieve folder to be scanned every minute. I set up a rule that moves all new messages to the InboxSpamSieve folder but nothing good happens after that. The messages do not move to either Junk or Inbox and Outlook-Filter Mailboxes and SpamSieve both become unresponsive and have to be Force Quit.
It seems to me that InboxSpamSieve folder is not being monitored and the app is becoming unresponsive due to my large Inbox.
I downloaded the latest version of Outlook Filter Mailboxes dated 10/4/17, but I am still not filtering the InboxSpamSieve mailbox. There is not an Outlook - Filter Mailboxes error message in Console, but SpamSieve is Not Responding. Outlook Filter Mailboxes just spontaneously closed itself.
There are some SpamSieve error messages in the Console. I am going to email you the error log.
Thanks. You can ignore the “Missing file group name” errors. Please update your Outlook scripts by choosing “Install Outlook Scripts” from the SpamSieve menu. If SpamSieve is not responding, that could certainly explain the behavior that you initially reported. The next time this happens, please record a sample report.
Thanks. It looks like SpamSieve is stuck waiting for the system address book to respond. It may help to restart your Mac. Or you could temporarily uncheck “Use macOS Contacts” in the preferences while we troubleshoot further.
Boom. Looks like I forgot the first principle of troubleshooting: reboot your system. Seems like it is working now. I am going to be out a few hours, so I’ll let it run and let you know if there are any further issues.
