Keybinding suggestion: cmd-delete to delete when preview has focus
Hello,
I read many web archives from within EagleFiler, where I store them until I have the time to read them, then I delete them. I usually put focus in the preview pane so that I can scroll using the arrow keys.
It would greatly streamline the experience if I could do the following:
  • when I’m done reading, I hit cmd-delete; this results in deleting the current record (even though the preview pane has focus);
  • the next record then is displayed (or the previous one if there is no next record), leaving the focus in the preview pane.
Right now, I either need to use the mouse to move back the selection to the record pane, or use shift-tab (which has a small bug that I reported earlier: shift-tab first select any text field in the archive when the preview pane has focus; hitting tab lets one navigate Record pane -> Preview pane -> Text fields in web archive -> Source List but shift tab goes Source List -> Preview pane -> Text fields in web archive (reverse order) -> Record pane).
The cmd-delete keybinding could also be enabled as a “delete current record” in every case a record is selected, independently of the focus.
Thanks.
Sounds good to me. Thanks.
With EagleFiler 1.3 you can press Command-Delete when the viewer has focus.
This is just wonderful, thanks a lot.
