Hoping there is a way to have a keyboard shortcut initiate the “Move” command, then give me some way to select the folder. Similar to how MailMate does it. I don’t think this is possible right now, but would love to be wrong about that. Assuming I’m not, has anyone had any luck using something like Keyboard Maestro or another tool to do this?
I tend to dump a lot of material into the top level Records, then work my way through it, so dragging and dropping is tedious.
