Keyboard Shortcut Key Help Required
Hello,
I’m using my single Mac laptop at home and at a work environment.
The OS is the latest with 10.8.1 installed. I have the latest version of EagleFiler installed as well.
At home, I use an Apple Wired Keyboard into my 27" Thunderbolt display. At work I use an Apple Bluetooth Keyboard with no external monitor.
For whatever reason, the only time the default EagleFiler CAPTURE and CAPTURE with Options keyboard shortcuts work, is at work on the bluetooth keyboard.
At home, it does not.
Any suggestions on how I can fix this please? I would like the shortcuts to be consistent for both keyboards.
Many thanks!
Chris
I’m not sure what would cause that. Which shortcuts have you assigned in the preferences? Maybe try holding down the fn key or choose a non-F-key shortcut.
That’s exactly the solution. I need to use the fn key when I’m using the wired keyboard for every corresponding F key.
The control, option or command key press combination doesn’t take.
Perfect - appreciate your response!
Chris
