I would like to modify the launch services so that my app is started automatically when the user double clicks a specific file type in finder.
Is this a task for DropDMG or should I be looking elsewhere?
Thanks
Thanks
DropDMG does not do that. You can change which app opens a file from the Finder’s Get Info window.
