I’m trying to restore Command-Shift-D as a shortcut for my Desktop in the Finder on 10.4. DropDMG seems to have taken that shortcut.
I don’t see DropDMG listed under System Prefs > Keyboard Shortcuts … which was mentioned in the manual.
Any help?
Any help?
System Preferences only shows the application keyboard shortcuts that have been customized. Click the + button, choose DropDMG from the Application pop-up menu, and type the name of the command whose keyboard shortcut you want to change.
Since Apple is now using Command-Shift-D in the Finder, a future version of DropDMG will not use this shortcut by default.
