Hello,
It’s been some days now that I cannot open Eagle Filer, it keeps showing the library opening window with a blocked progress bar.
Hello,
I suggest that you:
I can take a look at the report and try to figure out what’s going wrong.
Alternatively, if you need to use it right away, you could open it with Shift and rebuild your library.
Thanks Michael,
I sent you an email with the report.
Regards.
