Licence used over 2 machines
I have a SpamSieve licence (2 actually my office mate uses the other). I just want to know if I can use the same licence to alternately check my IMAP mail from desktop and laptop. I wouldn’t be using the same key live on more than one machine at a time.
Is this possible?
Thanks very much.
Scott
Yes. You can also use it on both of your Macs simultaneously.
Thanks for the quick reply!
