License Terms on SS
Is SS licensed per user or per CPU?
Thanks!
Each license for SpamSieve is good for one person or one computer–your choice. This means that you can use it on your desktop Mac and your laptop, or you and your family can use it (in separate user accounts) on a shared Mac. If there are multiple users on multiple Macs, you should purchase multiple licenses based on the number of Macs or the number of people (whichever is fewer).
licenses
A bit confused by the one computer but OK for desktop and laptop.
I have a mac at home and one at work that are mirror images of each other. I have SpamSieve on the Mac at home. Do I need a second license to run it on my mac at work?
Thanks
No, unless there are multiple people using SpamSieve on those Macs.
