It seems that DropDMG has problems with big folders. There is a folder with 96GB - DropDMG stops all the time. Is there a limitation or what can I do?
Thank you!
Thank you!
We’ve not heard any other reports of that. It should work with any sized folder if you have enough space. Could you explain more about what you are doing and you mean by “stops”?
Strange. The zipped file can be packed into a dmg without problems. I need to get to the bottom of this. Suspect a naming error.
