lost notes
Every now and then, notes I add to an item are not there when I return to it. I’ve got a feeling that I need to “do something” before leaving the input field for notes to have them saved. Like activating the tag-field or something similar. If I just leave the marker in the notes filed and then click on a new item the notes are lost.
/Anders
There are various actions that EagleFiler watches for in order to know when to save the notes. These include clicking in another window. The situation that you describe–clicking on a new item–is quite common, and when I tried it on my Mac EagleFiler did save the notes. I will go over the code and see if there are any cases that I missed, but if you could work out more specifically the situation in which it doesn’t save, that would certainly help.
I’ll keep an eye on it.
