I see there is a nifty script to allow Apple Mail to work with SpamSieve.
Is there a way to use a similar script that will allow Mailmate/SpamSieve to work with Sanebox without having Apple Mail involved?
I think I found my own solution (RTFM!)…
Section 3.4 > Filtering Other Mailboxes looks like it will do the trick.
Yes, MailMate has built-in support for doing this using a smart mailbox. You don’t need an extra script.
