Mailmaven, Spam Sieve and SaneBox
I am trying to shift to Mailmaven after years of using Postbox. My issue is that when SaneBox moves emails out of the inbox, SpamSieve doesn’t detect them as spam. Right now, I am being flooded with spam.
I saw an AppleScript that solves this problem in Apple Mail, but I don’t think it works with Mailmaven.
Any solution to this situation?
That script is no longer needed for Apple Mail because you can just use the Filter spam in other mailboxes feature.
I don’t know of a way to do this sort of filtering with MailMaven, and it doesn’t provide enough AppleScript access for us to write a script. I suggest sending the developers a feature request.
For now, one option would be to also run Apple Mail in the background so that it can filter these messages with SpamSieve:
  • Select Enable spam filtering using Mail extension in SpamSieve.
  • Uncheck Check inboxes for new messages not sent to Mail extension in SpamSieve.
  • Check (and configure) Filter spam in other mailboxes in SpamSieve.
  • Uncheck the Mail extension in Apple Mail.
Thanks Michael
Just to confirm the last step, you are say to uncheck the SpamSieve extension in Apple Mail.
I so missed having SpamSieve in Postbox after version 5.
Frank
Yes, uncheck SpamSieve in Mail’s settings:
Or, I guess it’s probably off by default if you had not specifically installed SpamSieve for Apple Mail.
Michael - one last thing, it looks like this works only while Mail is running. If I close it down, I lose the processing of the other mailboxes. Am I missing something.
Frank
Yes, Mail would need to be running, but you can close all the windows or hide the app if you don’t want it to disrupt whatever else you’re doing.
