Maintain Folder
I want to create a DMG with the contents maintained in the current folder structured (i.e. a dmg with Game.app in folder MyGame), instead of just Game.app getting added to the dmg.
Is this possible?
Yes. In this case, you would need to drag the folder containing MyGame onto DropDMG.
I’ve done that, but it creates a .dmg with the files in the folder (game.app), not the folder with the files in them (MyGame folder with game.app in it).
Here are some screenshots to show you exactly what I mean. I’m dropping the “My Folder” folder onto DropDMG.
Oh ok, gotcha thanks that works.
