Mass Rename Files via Hazel
I have about 400 files in EF. Their filename ends with “This is the title to keep || abc.com.webarchive”. I want to remove the " || abc.com". One idea I have is to use Hazel which make it easy. My question is, is it safe for Hazel to rename files in the EF library folder? I suppose I have to quit EF first but will it mess with the database? I appreciate guidance and help from you all here. Thank you.
Renaming files from outside of EagleFiler is not safe, but you could do this with the Replace in Filenames script.
You have thought of everything! I didn’t think to search the scripts website. Thank you!
