Menu bar - option to display remaining charge in %%
Good day!
Is it possible to display number instead of graphics representation of remaining charge?
Could be extra grand if it could be coloured too, but not sure if menu bar supports that.
It will show the battery percent in a tooltip if you hover the cursor over the icon. Are you also wanting to see a number next to the icon at all times?
It does, but I think colors tend not to look very good against all the different possible menu bar backgrounds/colors these days. Maybe coloring the fill within the battery level bar could work.
Yes, I was thinking about number visible all the time.
Also I have been using another soft on Windows, and instead of displaying all connected devices with their charge level, it displays only 1 device with the least charge in task bar. It could be a nice UI option as usually most ppl do not care how much juice their BT device has until it gets really low. And here colour indication could draw attention
A related idea I had was to only show the battery level when it’s low.
Great idea! If you allow to setup threshold to display low lever charge and color code it to boot - unmissable warning )
