Merging Email Libraries
This is more than likely a silly question but is it possible to merge two email libraries? The reason is simple. I created more than one library for different businesses and I’d like to merge them and make more use of the tagging feature.
Thanks for any advice.
Bill
Yes, you can drag and drop files and folders from one library window to another.
I was doing some thing silly trying to drag’n’drop individual messages instead of the ‘tray’ icons. Thank you for your support and the new version.
Bill
