I probably have something set up wrong, but after the update (which seems to have solved my pinwheeling/unresponsiveness issues) I’m getting double-processing. In the log, the first message has an origin of “Mail 16.0/3774.600.62 (SpamSieve extension 1.0.5)” and the second has “[mailbox] (IMAP) INBOX in Mail 16.0 (filter inboxes)”.
Could this be because I’m doing remote training? I’m using the 2022-12-27 version of Apple Mail - Remote Training.scpt, which seems to be the latest, but I did have a similar problem with a previous version.
Maybe what’s new then is getting duplicate alerts? I’m using SpamSieve’s “Play sound” and get the sound for both events. Should I turn off “Check inboxes…”?
You can probably prevent duplicate sounds by setting SpamSieve to check for new messages more frequently, like every 5 seconds. Or you could turn off the Mail extension in Mail’s settings. I’m working on a better way to prevent duplicate notifications while still enabling both types of filtering.
