Move records from AppleScript
I have a referene to a record, how do I move it into the folder named “2009”?
There is a move command. Also the record’s container property seems to be writable.
But how do I get a reference to the folder? Iterating over root folder?
You can get to the folder by name:
set _2009 to library record "2009" of root folder
Then to do the move:
set _record's container to _2009
It seemed so daunting that I didn’t try indexing…
Thanks!
