Is it possible to run a query against multiple libraries?
The searching I’ve done on the forums would indicate it is not possible, but I wanted to check to see if that is old information at this point.
I’d love to split my data into home/work, but retain the optional ability to search across libraries to find data from one library that has unintentionally (or otherwise) bled into the other.
Mike
