Pardon me if this has been asked before. But I could not find my answer. I frequently have documents that are multiple pages. EagleFiler seems to import the pages individually. Is there a way to merge pages together. Instead of having individual pages that are separate and do not have association to each other.
What kind of files are you talking about? EagleFiler definitely supports multi-page documents (e.g. PDFs and Word files). It never splits a file into pieces.
PDF’s. When I scan documents into EagleFiler, they show up as individual documents. How can I merge them. Or is there a better way to scan them. I am using a Fujitsu ScanSnap S1100i.
The ScanSnap software should automatically make a single multi-page PDF document unless you pause in between scanning sheets. You can merge PDFs manually using Preview or automatically via Automator.
