Just reinstalled SS after a drive failure. Never had issues before, now its not catching anything,. Created a new corpus, been training yet nothing. Should there be a rule created in the mail pref pane per your tutorials? If so, I do not see one. The app is installed in Mail and does manually move mail to spam folder from message menu but not auto as it should. Any suggestions>
Yes, you need to follow all the instructions for setting up Mail.
been so long since I originally installed, I presumed it was auto… the upside of that is it worked so well for so long I did not have to mess with it,
Thanks for your help
