I’d like to be able to add a “Note” to a folder. Is this possible, or are there alternatives? I usually need this for the libraries that I don’t use tags in.
Yes, you can do this by selecting the folder in the records list and clicking the Info button. A quick way to select the folder in the records list is to click on it in the source list and press Command-Up.
Thanks. I was selecting the folder in the Records list and then the Info button. However, the Inspector is not active when you do it this way. I now see you have to select the folder in the Source list, then the Info button.
You have to select it in the records list.
As much as I tried, I figured I was going to get the terms mixed up. So, yes I meant “records list”.
