is this the same issue? I can get everything to work well, but Apple Mail hangs every few minutes while running a script. Activity monitor reports:
“oascript not responding” and I can identify this script working through Apple Mail. I can’t type or do anything in Mail until it releases, generally a minute or two.
I moved this to a new thread because it sounds like a different issue, possibly not related to SpamSieve. Which script are you running? Have you tried recording a sample report of Mail?
I’ve afraid that doesn’t answer either of my questions. Please explain which script you mean when you say “I can identify this script working through Apple Mail.” How are you invoking the script?
I am still encountering massive email slowdowns with Spam Sieve. Apple Mail shows these absurd incoming message reports (currently showing 17166 of 17194 incoming messages). I’m guessing something is happening like moving mail from the junk mail folder to the spam folder is prompting Apple Mail to redownload ALL my mail and reindex everything.
When I look at activity monitor, two processes show up as “not responding”:
Mail (of course)
oascript
I think the second must be one of the two SpamSieve scripts that are being run.
I’ve tried to change the behavior of my email accounts (I have four of them) by unchecking this behavior: “Store junk mail on server” but that seems to completely undermine the whole reason for SpamSieve.
I have sampled the processes again and have included them here, but i suspect the response will be that the system is hanging while Mail is polling my server. I get that, but is there any way around this?
You posted this in a different thread, but it doesn’t seem to belong there, so I moved it here.
Are you seeing that in the main Mail window or in the separate Activity window?
osascript is not used by SpamSieve proper on Mac OS X 10.9. It’s probably from the Apple Mail - Server Junk Mailbox script that you are using. Please make sure that you are using the latest (August 29, 2014 as of this writing) version of that script.
Secondly, the script will be a lot slower if you have messages in the server Junk mailbox that are deleted but not expunged. Perhaps you can expunge any unwanted messages by logging into Web mail.
My “general” GMAIL account had just 30 or so emails in the Spam folder.
But my College’s GMAIL account had over 1500!
So that may be the solution. I may be able to address this with my College, but any idea why one account would apparently accumulate (not delete) the spam while the other would maintain them?
The flow into the College account is a LOT higher, like 100+ a day.
I’m trying to sequentially add accounts to the script to see if I can isolate the account causing the trouble.
I think it’s not that the messages are treated differently, its just that the flow into one of the accounts is so heavy (100-150 a day) that combined with the standard (and apparently impossible to reset) Google mail 30 day retention of messages in the Spam folder, this folder quickly becomes huge. After 30 days for example it will have 30,000 emails in it, even though SpamSieve has processed and identified as spam 95% or more of them.
If SpamSieve really re-processes that folder every time, that would be a source of the slow down.
