Outlook - Filer Mailboxes not ejecting
For what ever reason, I never read passed the instructions to “start filtering” and then to install the little program “outlook - filter mailboxes”. Installing today and the program never ejecting. Its quite annoying, is this required? I’m running the vastest version of Outlook for Mac
The outlook filter programming was installed today but now it won’t eject when it’s running. After I quit it will eject but restarting the program brings the file/program back up to be ejected. Any thoughts?
macOS won’t let you eject a disk image that’s storing a running app. You should follow the instructions to copy the Outlook Filter Mailboxes app to your Applications folder and run it from there instead.
