Partial import from Pinboard based on dates and tags
Hi,
I’m using Pinboard to save links, but want to create local copies of most of them as well, using Eaglefiler’s ability to create web archives. But the only export option available at Pinboard is a full html version of all saved urls.
I wonder if there is some way to have Eaglefiler to only import these newer than a specific date, and preferably also only bookmarks tagged with a certain tag?
Best regards,
Anders Thoresson
Pinboard’s HTML export is a bit limited, but there are more options if you use RSS. You can get an RSS feed for a particular tag. Perhaps you could adapt the Import From Instapaper via NetNewsWire script by substituting the URL so that the script can find your Pinboard feed in NetNewsWire.
