Path display
As far as I can see the only permanent indication of where in a library a record lives is the Container column.
This is a problem when nested folders don’t have unique names, e.g. in a search result /Projects/A/Reports/Final.pdf and /Projects/B/Reports/Final.pdf are indistinguishable. It’s nice that the tooltips don’t disappear when you scrub the mouse through the list, but I still can’t visually scan.
(for various reasons I’m moving to flat hierarchies and names like “Project A Final Report.pdf”, but there is a lot of legacy data)
Maybe EF could gain a path column? Or I could write a script to put it in the From field…
Yes, I’m planning to add a Path column.
