I use a fairly long list of folders to manage projects/personal/research. I tend to be working on one or two things at a time and it would be helpful to be able to pin/favourite the relevant folders to the top of the list. Is there a way of doing this, or a workaround. I thought about using a tag but I can’t see how to tag a folder.
I agree that it would be useful to be able to pin folders. There are a few workarounds at present:
You can tag a folder (first search for it under Records), and then it will appear under that tag in the source list.
You can create a smart folder that shows the same contents as the folder, and then it will always be visible at the top level of the source list.
You can open multiple tabs (or windows) for your library and keep each one set to showing the folder for a different current project.
Many thanks. Now that I know how to tag folders (should have figured that out - completely logical!) I can tag them as “favourites” and I’ve created a smart folder called “__favourites” which includes everything tagged that way.
The neat thing is I can also ‘favourite’ individual files elsewhere which I might be working with.
Thanks!
+1 for this idea
