Possible to move text inspector bar?
Would it be possible to have the option to move the text inspector bar down to the preview window instead of the main window? This is closer to where editing RTFs actually takes place. It would also not cause things to jump when the text inspector bar appears when selecting an RTF record (although I’ve set the program to always show the bar to avoid this particular issue).
Thanks.
If you mean preview window, no because the OS doesn’t support editing in Quick Look previews.
If you mean preview pane, no because the OS determines the placement of the bar, and the location is not customizable.
