Postbox and SpamSieve
Hi,
I am trying SpamSieve with Postbox 2.5.1 and on launching Postbox , SpamSieve does not start and appear in the dock, I have to start SpamSieve manually and then all seems to be working OK.
Any help appreciated.
Thanks
Steve
SpamSieve is not supposed to auto-launch when you launch Postbox. However, it should launch when there are new messages that need to be filtered and when you train a message.
Thank you Michael for your prompt reply.
All appears OK then.
