Printing to EF
I’ve been searching the forum because I was sure that someone had asked this before, but did not find the answer.
My question is whether it is possible to have the same dialog as with Option+F1 come up when you select Print To EF from the printing dialog? Maybe AppleScript, unfortunately I am not very proficient in it :frowning:
Not currently, but it’s a feature I’m considering. It cannot be done with AppleScript.
With EagleFiler 1.5 you can hold down the Option key to have it show the Options window.
