I subscribe to several newspapers, for example The Times (London) and the Washington Post. I cannot import items to my EagleFiler archive from some media because I cannot enter my userID from EagleFiler. Instead of getting an archived article, I get a message saying I must subscribe, but I am already subscribed!
Saving as web archive in Safari to the “importing web pages” folder. I get the message “Please subscribe”
Saving as pdf in Safari and placing it in the “importing web pages” folder: I get the text only, no pictures or comments. I guess that is better than nothing
Thank you. I import the page (or selected bit) as rich text then, which is quite messy compared with a web archive, but I guess that is the way to workaround.
Another way would be to enable me to log in from Eaglefiler which does not work at the moment
I have contacted one of the newspapers which will not let me import web archives into EagleFiler to ask them why I cannot archive files and to fix the problem.
If you’re using Safari, unless you’ve changed the ImportTextAsWebArchiveesoteric preference, it should import the text as a Web archive. So if you Select All it should look exactly the same as what you see in the browser. Firefox only supports rich text, which does not preserve the formatting as well.
I think it has to do with whether the site lets you stay logged in via a persistent cookie or whether the login is confined to a particular session in the browser.
Yes, it is working very well and I think I’ll use Cmd% from now on (even though it isn’t as fast as your import scripts) for all of my items so that if/when I unsubscribe from an online medium the webarchives are not in danger of disappearing, as they have done for dozens of imported stories (just recently discovered their loss = hours of wasted time importing them).
The “comments” are comments from readers of the article. I am not too fussed about webarchiving all of them.
