Hey Michael,
thanks for being on your toes, great to see you already got a beta handy for 10.14.
Unfortunately, I can’t get it to work. Being the dork that I am, I forgot to update Spamsieve before installing 10.14. Now I tried everything the support pages offer, but I can’t get it to work.
I reinstalled Spamsieve, did the upgrade to the latest beta and added Spamsieve as prompted to the privacy settings. Everything seemed ok, but I still can’t see the Spamsieve commands in Apple Mail.
There is no way to click on “Install Apple Mail Plug-in” from the Spamsieve menu to set it up, because the menu won’t show when I try to open Spamsieve. Nothing happens, at least nothing I could see.
Trying to get the plugin unstuck in the terminal doesn’t work either, because /usr/libexec/PlistBuddy com.apple.mail.plist -c ‘Add EnableBundles bool YES’ simply returns “error reading file”, even though the file is right there and I have all the necessary permissions according to the “Get Info” screen.
So basically I’m at a loss. Would be great if you could help me out in any way, shape or form.
Thanks in advance!
