I’m currently using EagleFiler 1.1.6, it works great, love the features, and nest folder, but somehow, i’m using PPC G4, 1.2 Ghz, 512 ram, it somehow really slow, why is that? will you suggest anything i can do to speed up
I can help you better if you tell me which operations, specifically, are slow. Also, how many records are in your library? Are there items in EagleFiler’s Activity Viewer window? Which other applications do you have open? (512 MB of RAM doesn’t go as far as it once did.)
EagleFiler 1.2 is much faster, although it will still take a while to launch on a G4.
