Quick question about blocklist
In my block list, I have an entry towards the bottom that is unchecked. The entry is src="cid:
I don’t believe I’ve ever touched this list. What does this entry do?
Kind Regards
It’s a built-in rule that block messages with certain kinds of embedded images. It’s unchecked because at some point you trained SpamSieve with a good message that matched the rule, so it was no longer a good indicator of spam messages and SpamSieve disabled it.
okay, thanks for the information.
Kind Regards
