Hi! I’m new around here. I’m looking for a way to create an incremental archive of my Gmail: to periodically archive older messages and then, probably, delete them from Google’s servers. Maybe once every three months. I would do this probably just on my laptop, though storing on my NAS could be nice too.
Reading through the docs and researching via LLM I get the sense that the best way to do this is via Apple Mail but I’m nervous: in past years when I’ve tried to do batch operations via Mail, it’s felt unreliable and unstable.
LLM research also yielded something called GYB, but I don’t see any record of its use with EagleFiler.
I’ve not used that, but it looks like it can download/update a folder of .eml files, which should work fine with EagleFiler. It’s OK to add new files to a folder EagleFiler is managing; you just don’t want to move/delete files.
Personally, I archive e-mailvia Apple Mail and haven’t had any problems. I’m not really sure what you mean by unreliable/unstable.
What I mean by unreliable/unstable: a number of years ago I used Apple Mail to migrate from a standard IMAP-based provider to Gmail, by dragging messages/folders over from one account to the other. I found the process to be buggy and ended up having to do it in small batches: sometimes there would be weird errors, sometimes silent failures before the copy finished, and usually a few messages missing at the end of the copy. I made it work but it was really tedious.
Good to know about GYB. Seems like a potentially effective solution, but I wonder if the Mail approach is safer since it’s a known path for EagleFiler…
I guess that also raises another question: what’s the main benefit of using EagleFiler for this vs. simply storing the mail in local mailboxes inside Mail?
Yes, moving messages between accounts is buggy in Apple Mail. EagleFiler avoids this problem by reading the messages in their current locations. It will also warn you when a message isn’t fully downloaded, so that you can redownload it in Mail, and make sure EagleFiler archives a complete copy, whereas moving an incomplete message with Mail will sever the link to the server so that you can never get the complete message.
The normal Mail import for EagleFiler will also save the messages in mbox format (rather than .eml files), which is much more efficient.
Speeds up Mail, more reliable storage, better searching…
