Remove Applications alias folder title?
Hi,
I’m evaluating DropDMG. I was wondering if it’s possible to remove the text from below the Applications alias in the dmg window? When I build a dmg manually I can do that. I’m using 3.2.4.
Michael
Every file/folder has to have a name. Do you mean that you want to make it something invisible, like a space?
