Removing files from Trash
I once inadvertently transferred a couple of files to Trash and wanted to restore them to the library, ie transfer them out of Trash. I could not find any command that would do this. The z-command (undo) was not applicable because several other actions had occurred in the meantime. How can I do this?
The only way to have EagleFiler automatically put them back where they came from is to use Undo. However, you can always drag files out of the trash and drop them onto the Library source or another folder.
