I’ve not been using EagleFiler long, but I like what I see so far! I am however having a problem while getting used to the program (trying to remember to use EF to organize the library), which is that I keep make directories directly inside the library by drag and drop, bypassing EagleFiler. Is there any way I can get EagleFiler to rescan the library and add the new folders and files, or must I find them, move them out, and then import them again?
Not currently. However, you can drag a new folder into an EagleFiler window (or into the To Import folder) in order to add the new folder (and its contents).
