Reset Hotkey?
When I installed Spamsieve I somehow set the hotkey for classify as junk to <command><option>j
Darned if I can remember how.
For whatever reason, it has reset to the default of <command><control>s
How can I change it back? I’m using it with Entourage.
Richard
Changing the Entourage keyboard shortcuts is not a feature of SpamSieve. The shortcut is determined by the name of the file that SpamSieve installs, e.g. “SpamSieve - Train Spam\cmS” where the “\cmS” means “Control-Command-S”. I do not recommend renaming the files. You can, however, override the keyboard shortcuts for any Mac OS X application by going to the Keyboard pane in System Preferences.
