Right-Click Contextual Menu Feature?
I am looking to convert over to EagleFiler, but I have one request that I need to do so:
Right-click contextual menu EagleFiler feature that allows me to import into EagleFiler versus a key combination. Will this feature be implemented in the future? Thanks.
Please tell me more specifically what you mean by that. At present, you can import from the Finder by pressing the capture key, as well as other means.
PM sent.
