Right-click on records may not allow every action
Hello,
If the focus of the application is in the preview pane, right-clicking on an entry in the record list does not allow every options. (This happened to me when doing the following: I was reading a web archive, using the keyboard to move around, hence the focus was in the preview pane. I then decided I wanted to visit the source url to see updated comments and found that I could neither do it using the menu or a right click on the record entry.)
Thanks for the report.
This is fixed in EagleFiler 1.2.2.
