RTF capture not working for FF3
Hello.
I am able to capture text from web pages just fine in Safari, either using the keyboard shortcut or the Services menu. However, I can’t capture selected text as RTF from FF3 - the key strokes don’t work, and the EagleFiler option is grayed out in the Services menu.
FYI, I am on v3.0.1.
Robin
“Capture” is a specific term that means importing using EagleFiler’s capture key. In a Web browser, this will import the whole page.
What you are referring to is called the “EagleFiler: Import” service. None of your other services are enabled, either. This is because Firefox does not support Mac OS X’s services feature. You can import selected text from Firefox via drag and drop. To use a keystroke, you would need to use a browser that supports services.
Okay then, that’s as good an explanation as any.
Was this true in FF2? is this something that’s going to be “fixed”?
Firefox 2 also does not support services. I do not know whether the Mozilla developers plan to do so in the future.
