Running on whole inbox (not just incoming mail)
Is there a way to run Spam Sieve on all messages in my Inbox initially and then on incoming mail as would be normally expected? The use case is to hopefully remove spam from my Inbox, which as a lot of email in it, upon initial install so that I know it is under control and then have filtering handle all incoming mail afterwards.
Thank you
Yes, after you do the initial training you could select the inbox messages and choose Filter Messages.
Thank you. This is great!
