I have no use for the Unfiled and Untagged Smart Folders. If I delete those plists from the Smart Folder directory, will it break anything?
Thanks.
EF 1.8.4
macOS 10.13.6
Thanks.
EF 1.8.4
macOS 10.13.6
No, but I think they will probably come back. I’m planning to add a way to hide them. In the meantime, another option would be to put them inside a collapsed folder.
Tolerable workaround. Thanks.
