I’m using Chrome 133.0.6943.142 (Official Build) (arm64) and EagleFiler 1.9.16, on OSX 15.3.1. If I try to use the Save to EagleFiler option from the Print using system dialog menu, the first time I get an error message “Print Failed Something went wrong when trying to print. Please check your printer and try again”. Thereafter, the function fails silently. The function works correctly in Safari, so this is probably a Chrome fault. However, that which does not get reported does not get fixed - any thoughts?
Just to be clear, after you close Print in Chrome, are you clicking Print using system dialog?
I’m getting that error, too, and the built-in print services to Save to iCloud Drive and Send to Mail don’t work form Chrome, either, so this looks like a Chrome bug.
Hi Michael and greetings from Australia
Yes. Print using system dialog. It used to work, and seemed to stop working around February 4th.
regards
Melodie
Understood. When I have 5 minutes I’ll log a fault with the Chrome Community.
regards
Melodie
