Hi,
I’m using DropDMG to shift data from lots of PGP Disks one mac over to .sparsebundles on a new imac (where its been a real timesaver), and to create preconfigured new blank images on the new machine. On the new imac, I’m storing the passwords for the disk images in a keychain on a USB stick - this new keychain is not the default for the imac, which remains the login keychain. I thought it would also make sense to keep the passwords from DropDMG configurations for new disks on the same USB keychain, but it doesn’t seem to want to play. If I drag and drop the passwords to the new keychain, the password fields in the DropDMG configurations won’t be populated the next time I open the application.
Can you suggest a solution to this, or is it just the case that DropDMG only works with the default keychain, or perhaps even only the login keychain?
Many thanks for any suggestions!
