saving when using old file as template
Hi Michael,
I once asked about throwing away files once one had imported them into EF - makes sense.
Now once that is done, I have a procedural question. I like to use old files as templates such as when I bill someone or make a label. Normally I would open the file and then use “save as” to create the new file. Do you have suggestions of how I might do this when a file is in EF. I can’t just use “save as” because then EF would not know it. I suppose I could create a pdf, but i want the file in its native format. Any thoughts?
John
I would Save As into the To Import folder. Another option would be to select the template file and run the duplicate script.
EagleFiler 1.4 has a stationery feature to make this easy.
