When ScanSnap Manager would not work after upgrading to Mojave, I went to the Fujitsu Page to get the Mojave driver, found the following:
"Software Downloads: ScanSnap S1300i
As legacy ScanSnap Software (such as ScanSnap Manager, ScanSnap Organizer, or CardMinder) is a 32-bit application, it may not work properly on future macOSnew window.
Use ScanSnap Home instead.
Setup Programs
Setup Programs
Those using ScanSnap Home
ScanSnap Home is a desktop application that edits, manages, and utilizes scanned data from documents, business cards, photos, and receipts to increase your productivity.
Introduction of ScanSnap Homenew window
Attention
The following software will be uninstalled by installing ScanSnap Home:
ScanSnap Manager
ScanSnap Organizer
ScanSnap Receipt
CardMinder
ScanSnap Cloud
Also, ScanSnap Home does not offer some functions which have been available with the software above. For details, please refer to PDF Removed Functions.
Software Release date
ScanSnap Home Download Installer 1.2.1 Download new-window May 9, 2019
ABBYY FineReader for ScanSnap™ 5.5 Download April 13, 2017
When the setup has completed, check for the latest updates and apply them all prior to using the scanner.
If you are installing ScanSnap Home onto a computer without an internet connection, use the offline installer. "
I thought that “Home” would have the same features as ScanSnap Manager, not replace it. WRONG! I hope i missed something but up until now I have not found a solution. Believe I’ll try VueScan. Thanks, Bill BTW, HOME does work to some extent and is very similar in appearance to MARINER Software’s PAPERLESS 3. The same response was listed for my driver search for the iX 1100i
